nokiauk
524
25
Edinburgh
I'm aware the new MQB A0 platform that new Ibiza/Polo is on is new, however I though it would be worth having a thread dedicated to coding should anyone have tried anything that works.
I personally have OBD Eleven but haven't discovered that much that can be coded as yet, there are apps for some basic things however.
Mirror Fold on 1 click ( Remote or Handle (kessy))
1 - Module 09 - Central Electrics
2 - Adaptation
3 - Select - Spiegelverstellung
4 - Sub - Funk Spiegelanklappung Modus
5 - Change value "Funk Spiegelanklappung Modus to by Look Command
I'll take a look into how this may be achieved, tried mirror dip again and no luck, I have been advised this may not be possible on this platform.
Notification sound on Lock/Unlock or Both:
2 - Adaptation
3 - Select - Acknowledgement Signals
4 - Select - Akustische Rueckmeldung entriegen (Active) for sound on unlock
5 - Select - Akustische Rueckmeldung verriegeln (Active) for sound on lock
6 - Select - Menuesteuerung akustische Rueckmeldung (Active) to enable the menu option
7 - Infotainment press Car then setup
8 - Select Opening & Closing
9 - Tick in Acoustic Conformation (this can now be used to turn on/off this feature)
Now in the UK at least this uses the alarm (if fitted FR & Excellence) on other models and non-uk cars this may simply sound the horn.
Did you find a way to do mirroe tilt when in reverse mode i have execellce DSG
Also can you clarify if we can activate windows autoclose without a long press (does it use the rain sensor)
I have a doubt on this because if the rain sensor is always active it may get my baterry drain , or does i stop checking if the car is locked with windows closed???
2 - Adaptation
do you find a way to activate mirror tilt on reverse i have dsg motor excelence version
and about the windows to auto close if rain does it drain much baterry because if window is opened and is not raining it will stay opened
it should allow if car is closed then check windows
2 - Adaptation
There is someway to activate side front sensor and rear sensor when in reverse ( it just activate rear because its in reverse) bit i would like to know if front pass when parking
2 - Adaptation
Did you find a way to to mirror tilt when in reverse mode( i have a dsg)
Do you know how to activate cornering ligths with Ibiza LED i have dsg version
I dont understand why its not available do you know?
2 - Adaptation
As I don't have te OBD device is this something the dealer would activate for me?
Be cheaper to buy an obd devise I bet, you can always give a shout out and see if there are any kind soles who live near you that can do it for you.
