Guest, 🎅🎄Looking for a stocking filler idea? Why not treat yourself or a loved one to our high quality CUPRA or SEAT valve caps. Order now from the merchandise store
many of the cheap Chinese ELM 327 are not compatible. The ones labelled v2.1 especially.Carista uses ELM327 dongle (there are loads of them out there) or example https://www.amazon.co.uk/ELM327-Sca...pID=414hZeSsuSL&preST=_SY300_QL70_&dpSrc=srch but i am sure you can get them cheaper
There are some threads on here about how you can get a better deal with Carista if you sign up for pro service (that you pay for yearly) then cancel after the months free trial. Not my tool so have a search through the site.
Well I used to use Carista but my current car doesn't support that feature.Does anyone know how to get the speedo/rev counter needles to do a swipe round when the ignition is turned on?
I have a Carista OBD and downloaded the app to hopefully enable mirror fold on single click on my 2018 Ibiza FR. As you say this model isn't supported yet. HOWEVER I then emailed support and they allowed me access to the beta version. Lots and lots of options some of which are out of my comfort zone but look interesting. The single click option worked great.... If you are comfortable working with beta versions it's an option.
Well bought the Carista dongle and got the beta software and now my wing mirrors fold automatically when I lock the doorsAny other suggestions for useful things that can be changed?
only if they are canbus error free , i try normal LEDs and got error on the infotainment.Does any one now if is it possible to swap front fog lamps to leds?
Thanks theoldboy I will tray it.By the way I have a vw polo from 2019 do you now if the procedure is the same?Eliminate the error of the led lamps in front fog lights All models
If you are thinking of putting LEDS in the front fog lights, with this modification you will avoid the error of failure of the bulb.
1 - Module 09 - Electronic control unit. Code (31347)
2 - Adaptation
3 - Leuchte13NL RB5
4 - Lassttyp 13 - (Change value to Led Lichtmodul)
5 - Dimmwert AB13 - (Change value to 127)
6 - Leuchte12NL LB45
7 - Lassttyp 12 - (Change value to Led Lichtmodul)
8 - Dimmwert AB12 - (Change value to 127)
Read more: http://forum.obdeleven.com/thread/6342/adaptions-spanish-site#ixzz5w8LxYaze
@Ghost45 Ibiza is not my car but i have seen this thread on the OBD11 Forum http://obdeleven.proboards.com/thread/3450/2017-ibiza-adaptations-tried-tested
