Feb 22, 2009
3,459
South Wales
Address 01: Engine Labels: 038-906-019-ARL.LBL
Controller: 038 906 019 KG
Component: 1,9l R4 EDC G200SG 5342
Coding: 10102
Shop #: WSC 06402
VSSZZZ1MZ5R006923 SEZ7Z0D2664066
2 Faults Found:
18009 - Relay for Supply Voltage Terminal 30 (J317): Implausible Signal
P1601 - 35-00 - -
17071 - ECM Power Relay Control Circuit (J271): Short to Plus
P0687 - 35-00 - -
Readiness: N/A
Engine Control Module Power Relay Control Circuit High
Possible causes
- Weak battery- Low voltage while cranking
- Poor engine control module electrical connection
- Open or short engine control module circuit
- Failed Fuse
- Faulty relay
Anyone have any suggestions where to start or een have photos highlighting what I need to check - Thanks in advance
Is the car running ok? That relay it refers to is the relay 109, that's the main power for the ecu. I think terminal 30 is something to do with the battery and central electrics or some such thing. Anyway from what I could find it's worth cleaning the battery terminals and earths etc and maybe try a new 109 relay for good measure.
