Today i was on dyno and it was very horrible
Running super lean, low power, low torque...Leon is originaly auq, but has aguengine in, k03s, stage 1, forge fmic, TIP, decat 70mm exhaust...
And now my car wont idle smoothly, on my gauge usual vac level is -9, and it is -4-5, running very rich, u can feel the smell of fuel..when i am driving it seems normal, except very loud missfires when letting of throttle, and i mean after a gentle acceleration..
Checked DV (forge 007p), seems ok, when i push piston invards and put my finger on DV top nipple, it holds, when i let go DV piston pops back.
MAF seems ok, read 175 on dyno
I did n249 bypass
I have 3.6 bar FPR, and judging by graph, very bad fuel pump, can this be related?
I once had throttle position error on vag com, and today i had somethin saying Pressure Drop between Turbo and Throttle Valve (check D.V.!)
Thanx for your help guys.
I did n249 bypass
One way valves working ok, PCV also ok, no visible holes, leaks...
