Icecavern said:Can't use the existing gearbox unfortunately. 6 cylinder gearboxes bolt on differently so the bell housing ( I think that was it ) is different to 4 cylinder ones.
You don't have to go wide track IIRC but can't remember which bits you need.
Pete
so i dont need to change the hubs then?dougy69 said:i didnt change the rear subframe when i did mine.
as for hubs and brakes etc it depends if your going to use four or 5 stud!!
gearbox is a must only vr6 one will fit
i changed all the mounts for up-rated ones
and as for the clutch been cable, you need a vw part that fits into the gearbox were the hydrolic bit is. i will get the part number for you if you go ahead and do this.
i also needed to change the gear stick and mechanism
Sorry mate but, there are only two types:IbiVR said:Engine wise theres 3 types up to 93 is distributer, after that is coilpack, you get an obd2 verison form 97 which is a bit different and better if you can get it.
for conversion your better with a golf really, because of the other bits that fit, i think the box on a sharon is wrong, passat is close but you wont quite have all the bits you'll need.
for a cheap donor your best bet is a 94/95 golf.
Tom.
sixpot said:
IbiVR said:Nope, defo three.
Only very early vr's were dizzy. OBD1 coilpack from 93.
ECU codes for Dizzy OBD1 are 021 906 258 A B C
Ecu codes for the coilpack ODB1's - 021 906 258 AG AF CH CP BM EA BK
OBD2 is 021 906 256 XX or 02 1906 259 XX
I have one in my car, and 2 in my garage, believe.
Tom.
dougy69 said:been driving mine now for a good few weeks and tbh its slow up until about 5k revs. after that it pulls like hell and sounds mint like!!
ibizavr how much did it cost you for the turbo etc and can i get the same done to mine at a good price??
