vtune-need more boost
leedc5
i've had a vtune map on my car, its a k04 conversion with all the mods to suit, boost wise its hitting 14psi over boost and settling at 11/12 psi through to redline, its still a quick little car but not quick enough, i've had it adjusted twice now by the company but im not really that happy, what are my options? its also had a new n75 and coilpacks and there are no fault codes on vagcom, any help would be much appriciated, thanks
SidewaysCupra
106
Carmarthen
Sounds like a poor map too me. Mine hits 21 psi on custom code stage 2.
In my opinion you should stick to a tried and tested map from either revo, custom code, jabbasport or p-torque (or anybody else that i've forgotten with a good track record).
Never heard of vtune myself.
There are a lot of people out there with laptops and cheapo **** bought from ebay.
wild willy
2,313
Wales
The only Vtune i know of is the free program used to adjust APR remaps.I use it and its great. You can request more boost from it. Are you sure your turbo has more to give. post up some vagcom logs.
leedc5
i haven't got vagcom myself but will try get hold of it of someone to get some logs. Hope the turbo's got more in it, its a k04 off a s3/tt 225 with 10k on it, that is the vtune as in the link above
leedc5
at first i thought my boost gauge could be knackered but after having a little blast against a glanza earlier i know its not as quick as it should be. What are my options now? Is it easy enough to just go to another company who can remap it again?
leedc5
i'm based in bristol mate, don't mind abit of travelling for a decent place. Cheers for your help
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
18
glos.uk
what other parts do you have on the car to go with the K04?
injectors?
S3 maf?
FMIC?
bigger DP & cat/exhaust??
wideband afr gauge?
JJ_arosa
hi lee im down the road from you in south wales. i took my k03s cupra to bill bager 5 in gloucester
id recomend a custome code, my old k04 cupra held 20psi and it was 278 bhp went very well, price wise your looking at 350 - 400 irc (that was also custom code)
the map you have sounds w**k
leedc5
its got a fmic, s3 maf and injectors, k04 downpipe, full stainless exhaust, i bought the car with all the mods done, all i had to do was buy a new ecu and replace the n75 and coilpacks and give it a service
leedc5
its silver mate, bought it off a mate of mine in bristol, you know the car?
JJ_arosa
is it my old one lol ?? pic in my avotor <--------
did not need new ecu tho when i solt it, and it boosted fine if it is my old one
leedc5
na thats not it mate, very similar though. Think i might have to go for the custom code this time, more bloody money lol. I bought the car for 2800 which wasn't to bad really
JJ_arosa
i solt mine few days ago for 5300.00 k04 conversion with all the goodies.
so you had that very cheap if all is good with body work and engine.
leedc5
it is in very good condition, got 79k on the clock, got coilovers, 17" superleggras sprayed black, all the engine work ko4 etc, new ecu, autogauge boost, oil temp and volt gauges, all the common problems fixed, just done the n249 by pass. Soon as its mapped properly it'll be a nice lil car
