VW Golf Mk3 TDi lack of power / VAG-COM Fault codes
k11jrp
old and wiser
Hello all, been ages since I was last here but nice to see some familiar faces.. Ive moved backwards now to a MK3 Golf TDi (estate) I know, how things change.. I am wondering if someone may be able to help with a Vag-Com fault code that I think is causing reduced power above 2000rpm and a rev spike on start up. No other symptoms. This code wont reset.
Control Module Part Number: 028 906 021 GG
Component and/or Version: 1,9l R4 EDC 00SG 1432
Software Coding: 00002
Work Shop Code: WSC 01317
1 Fault Found:
01237 - Fuel Shut-Off Valve (N109)
04-00 - Mechanical Malfunction
I have read about an o-ring being in the wrong place?? a plunger stuck?? or a relay malfunction?? Where abouts is this N109??
Any clues would be gratefully received.
Kind regards
Jon
k11jrp
old and wiser
I think this is the unit?? Can it be repaired or is it just a replacement?? Thanks again
