Warm start issue
Cuppyjoe
97
20
As above, when the engine is warm it's a bit lumpy initially. It's like the engine is over fuelling coz it doesn't know that it's hot.
Annoyingly, I recently changed the engine temperature sensor because I had an EML on and my cheap Amazon code scanner told me that there was a P1296 code. Code scanner then cleared the code and seemed a bit better.
Now my EML is back on the code reader won't connect to my ECU so I can't see if it is the same issue.
Any ideas?
I'd be surprised if it was MAF because it's fine on cold start and any other occasion. Could be a dodgy coolant temperature sensor?
Chaki
36
17
Check fuel pressure regulator, i had the same problem on volvo t5 model 850.
When cold it starts perfect but after some driving it cranks a lot then starts and i could smell raw fuel...
Reactions: Cuppyjoe
Cuppyjoe
97
20
Delphi. I've asked the seller to send me another which they are doing for free.
Cuppyjoe
97
20
Thanks. How do I check if it's the fpr?
mty12345
3,771
476
bristol
I agree that the coolant temp sensor is the most likely cause, not sure there is anyway of checking the FPR other than plumbing in a pressure gauge and measuring the fuel pressure.
Reactions: Cuppyjoe
Cuppyjoe
97
20
Got a new one on it's way, hopefully will cure it!
