If its going to split on the underside one, it'll split quite close to the manifold. I had to remove the N249 and N112 retention assembly on the LC to get to mine but the LCR doesn't have this afaik.
Log blocks 115 and 118. 118 has the boost duty cycle (the N75 requests sent from the ECU) and 115 has specified vs actual boost. When more boost is requested in block 115, you should see the boost duty cycle numbers getting close to 100 in block 118.
The fact that you're getting induction noise suggests that the turbo is spooling but the charge air is being lost somehow. If you don't have split hoses or a sticky dump valve, it must be going out the wastegate. I'd suspect that the N75 is past its best and isn't reacting quick enough to the ECU command for more boost by closing the wastegate.
