imperieumblue
Newbie
Aug 15, 2006
92
just fitted some textar brake pads and fount out that the discs looks a little warped nut much so what should i do replace the discs or what
Did Your Pads Cause This? As I Was Looking Into Pads From Gsf And Tehy Supply Textar.
new disk time then,.
textar are sucky pads tho..
local autoparts store cheap as things usually... so expect same again if they are used hard
comparing shite with shyte
Textar vs Jurid
If you run pukka pads you would know the difference and never look back - trust me
