alex 80
91
are the mk1 seats leon's known for having water leaks? i've only had mine for 2 weeks came home tonight to find all my window's steamed up.
looking inside the car i found that the carpets didn't feel wet but both front mats had little wet patches on them
i've not used the car since sunday night and it hadn't rained today
where should i be looking for the leaks??
thanks
i was like that last year till i selled the **** out of everything with tiger seal and touch wood(my head) it ant leaked since
When you open the doors, do you get water pouring out over the sills?
sorry for jumping in alex
when i got to mine at work to come home, the windows was steamed up so i checked the the footwells for water but nothing :confused::help::confused: any ideas lee?
fluctuation in temperature can cause a lot of cars to steam up - It would also be due to a leak!
Check all carpets but if everything feels dry then I think you're in the clear :)
not a fix for the leak but I have a moisture trap in my car similar to
kontrol%20streamline%20moisture%20trap%20ocean%20spray%20scent%20500g%20%C2%A34.99.jpg
picked mine up in local discount store B&M - hypervalue pound stop
i checked under all the mats both front and rear, passenger and drivers side. rubbed my hand over the carpet but all felt dry. it may be due to the temperture then, today started quite warm and sunny then went wet and cold. i may be just paranoid :) never noticed it before
^^ i like that, ill see how it goes for now, when the cars had the pollen filter changed if it still does it ill invest in one until i track down why its doing it in the first place.
I have some silica gel which should hopefully do the same thing. Not quite as cool at the pingi though!
