The carpet between the door and floor were 'bone dry' like yours BUT water was coming in through the door seal and through the underside of the underlay so wasn't making the carpet wet. You need to take the door cards off ideally and check the seals
Ok, just took the cards off and put silicone sealant which I bought from Halfords across the door metal carrier. I hope this resolves the issue. I don't need to take the door carriers off do I?
Ok, So after doing this how can i take the carpet out to dry? Isn't that a massive job? Or can i just use a hair dryer?
Hi,
After this weekends weather my rear drivers side footwell is now almost 2 INCHES deep in rain water!
I don't think its the usual inner door seal problem, appears the water is actually coming in UNDER the black rubber door seal...
SOOOOO annoying, as I was actually pretty proud that I'd finally got the whole car interior bone dry, took all summer!
Hi on my mk1 Leon cupra I seem to have a little water leak coming in from the peddle area deffo not the doors as they all been sealed.. Anyone know what it can be thanks
