Water leaking rear view mirror
380bhpdaily
1,261
574
The roof looks damaged from the photos it looks like it’s been peeled back as it’s curved up. Just checked both my mk2 Leon’s and my roofs are flat on the top of the screen. I’ve looked at the photos for a long time and it looks the same all the way long. That will be why it’s not sealing the metal work isn’t straight.
I’ve had a panel beater check the photos as well and unfortunately he’s said the same from the photos.
Reactions: jcbmally
SueFR
Doncaster
Mar 16, 2015
238
19
Doncaster
Hey,
the photo what you see is what I have put in. It was flat Iv put some seal inside it and it needed to be pushed in more.
The job before that was the wet sealant which I fooked up hence the bits of sealant left there I can’t remove haha
BigJase88
Jase
Apr 20, 2008
3,765
1,074
Yeah roof looks beat to buggery
380bhpdaily
1,261
574
Is it called that as I can’t find it?
My bad it was toolstatiom not screw fix.
Traction
210
Hi,
Were you able to confirm the cause/fix for the issue.
I'm having the exact same issue on my 2005 mk2 leon.
I noticed some drips from mirror and when I checked behind mirror it was soaking.
I took off the central light and I could see moisture/ condensation on the roof.
I've a towel stuffed in above the mirror and I have to keep changing it.
For past month the condensation inside has been worse than normal.
Also in icy weather the inside of windscreen was frosted over.
I'll try to get some pics, I haven't tried to fill in the seals....yet
Sent from my SM-G991B using Tapatalk
SueFR
Doncaster
Mar 16, 2015
238
19
Doncaster
Hi,
Hey,
yes it was the seal on the windscreen literally on that big only, I had that replaced and cost me £70 and to this day no more problems with leaks 😊
Reactions: Traction
Traction
210
Hey,
@SueFR
Thanks for confirming, great to hear the fix worked.
I'll definitely look into getting this done.
Traction
210
@SueFR
@SueFR
Sorry to dig this up again. The leak "magically" disappeared for a while and I foolishly thought that might be that.
But now it's back and I can't avoid it any more.
Did you need to have the windscreen taken out and put back in?
Or was it a case of pumping in more sealer?
SueFR
Doncaster
Mar 16, 2015
238
19
Doncaster
@SueFR
Haha that’s what happened with mine then it came back ..
nah I had someone out he took windscreen out and resealed the area that was ****** then out windscreen back in., no problems since ☺️
Traction
210
Cool, thanks (y)
I'm going to have to take the plunge.
Spoke with 2 different repair companies and they are both worried about it cracking.
Fingers crossed.
SueFR
Doncaster
Mar 16, 2015
238
19
Doncaster
Cool, thanks (y)
Fingers crossed.
Yep unfortunately that is the risk you take, and if it does crack then a full replacement windscreen at cost to you
