Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
this seems to be about something diffrent the water seems to sit on the door ledge
THIS is the reason why you have water sat on the door sill, before long you will have a swimming pool if you dont fix it, in fact if you check your carpet, you may find that its damp, if it is, then you have about 10 million gallons of water soaked into the sound deadening underneath. THe reason why water is sat on your door sill, is either the drain holes are blocked under the door or as everyone will testify, your door seals have perished, check the guide that Salsheikh has kindly put up and learn how to fix it. Its the bain of owning one of these Leons.![]()
no carpets are completey dry am thinkin maybe door seal not pushin water wer it should
i only had wet carpet on the passenger side. Found a thread on here where you make small cuts in the seal on the door sill, seemed strange at the time but no water collects on the sill now and no more wet carpet.
Mine holds on top of the door seal and drops onto the sill when I open the door after its been raining!
