Weird Electrical Stuff!!!
Funkyfin2000
Black Leon Cupra R 280bhp
Oct 6, 2005
2,477
Stafford, Staffordshire
Right then....
its gone in this morning...
looks like they have had another stafford cupra in with the same problems.....that turned out to be the window regulator.............!!!!!
Coz the signal for the windows and the locking goes through that doors of course!!!!!
We shall see....more updates later!
Funkyfin2000
Oct 6, 2005
2,477
Just had a call from the Auto Electricians....
appears to be it could be the window regulator...gonna strip it down and check it out for us.......
does anyone know if you can buy the regulator seperatly or have to buy the whole window unit?
Funkyfin2000
Oct 6, 2005
2,477
hahahah no confirmed as exact problem yet....
just waiting for confirmation tomorrow...
right whats the cheapest price for a new regulator! as looks like they are going to source one and it prob won't be cheap!
oz_borne
Return of the mac
Mar 31, 2006
77
Quedgeley, Gloucester
Glad you got this sorted, and sorry i ddin't reply but have been away for a long while
Might have this looked at myself......but did it stop the unlocking thing going on...mine has stopped with the windows, but continues with the unlocking whilst driving malarky!!!
:A:
djscorch
Innovate, don't imitate
Jun 30, 2006
398
Manchester
Mine has just started with the interior light and central locking clicking today!
How can you tell which one has got water in it? Will i be able to see if i take the door card off?
mrbubba
463
Sorry to resurect an old thread, but I did use the search feature :)
My Wifes 2004 Seat Leon SX has just started to do similar things. We had a lot of rain last night and when she went to come home this morning, the interior light wouldn't switch off. Then the electric windows wouldn't work and now the remote locking won't work.
Someone on a Skoda site said it could be the Comfort Control Module, a fure or the battery.
There is no Haynes manual for the car and I'm not sure where the fuses are. She's going to take my Skoda to work tonight, as I don't trust her car to work when she comes home, especially if it continues to rain as it is now.
Was also looking to download the VAG-Com software from the site in the FAQ, but I don't know what cable connection I would need for the Leon. In the list, it only shows for Audi and VW http://www.ross-tech.com/vag-com/download/
**** EDIT - Just noticed that this is in the Ibiza forum, so I'll put another thread in the Leon Forum ****
Neil
Super_Cupra_7
103
Dunfermline, Scotland
ITS FIXED!
Finally :)
£182 later i have a window regulator that has been fixed and RESEALED!!!!!
Cracking work!!!!
Collecting in a bit :)
Hey mate.
Was that from a main dealer?
I have the same gremlin problem in my car.
Have come back to my car on a couple of occasions to find all windows completely down, alarm still on and car very wet!
To add insult, drivers window now no longer works and makes a lovely grinding noise when the window switch is operated!
I have been quoted £340 for the part, diagnostic check and labour from Fife Seat.
I think that seems pretty steep, but may just have to get it done :(
Cheers,
Funkyfin2000
Oct 6, 2005
2,477
Hi mate,
best read the thread. You need an auto electrician and i guess it will be the water ingression in the window regulator.
That should sort ya!
Don't pay seat, you will be ripped off.
Rich
Righttoe
100% Welsh *******
Jul 21, 2008
220
Bexleyheath, UK
Hi guys, just thought i'd add to this to help anybody out that ever gets this. I had this problem start few weeks ago, with the car locking itself as soon as i started the engine. then it changed to putting the interior light on randomly and kept trying to unlock the car ever few seconds!
Searched around on here and it apeared to be a common fault with people, especially in damp/rain or frosty conditions!
As posted above by ****yfin2000, its the Comfort control module which is bolted onto the drivers side door window motor. I took off the door card, pealed back (carefully!!) the white screen, then you need to lower the window about 5cm, and you can see through 2 big cut out holes there are the 2 metal holders which grip the window, you can losen these using a 10mm socket then you can lift the window by hand and clamp/tape it up.
Once the window is secure there is 5 gold bolts holding in the motor essembly and runners, 3 at the front, 2 at the back, these just need to be losened, not taken out completely. then you can remove the back rail then the front rail, and unplug the cable to the motor.
I then took mine into the warm and checked it out, if you look at the front there is a L shaped silver cover by the plug, unscrew the 5 screws and remove the cover, mine was very damp inside.
I used a hair dryer to dry mine off then left it to sit in the warm for a hour to make sure it was completely dry. Then using some black silcone sealer, i sealed up any areas i thought could be better, around the plug seal and a little around the L shaped seal. Then put it all back together. and leave it dry!
I then refitted the unit to the door, dropped the window into place and tightened up everything, then refitted the door card.
Touch wood! it works perfect know, and it was doing it none stop with me, so fingers crossed its sorted!
Cost me nothing but a very small amount of silcone sealer and my own time!
Hope this helps you guys with the same problem!
May 29, 2008
675
Aberdeenshire
I randomly came across this thread on friday afternoon...not because i had this problem. Driving home on the friday night the passanger window dropped as soon as i started the car....spooky! it did it once again sitting at traffic lights...thought my gf was mucking around with the switch! take it the window regulator is on the way out! Not had any issue with the interior light coming on or the car locking itself (but chances are it will happen on the way home tonight haha)
