Wellycooler pipework recommendations please (20vt)
kiemcd
46
Hi all, as title says I've purchased a wellycooler for the car but now struggling to find a decent pipework set up, what are you lot using and what can you recommend?
I'm thinking of using the forge throttle body pipe and forge map sensor pipe so think I'd get away with a universal kit, well I'm hoping I can anyhow, looking for 2.5" pipework
Pic of car with cooler on as I can't wait to get it done lol
mike84
mike84
Dec 29, 2014
13
liverpool
I got the welly cooler I also used two 3"to2 1/2" reducer pipes coming off the cooler an bought the universal 2n1/2" pipe kit off flea bay of course it involves a bit of nouse an patience but easy enough I also just bodged a map sensor hole using the old bit off the old intercooler an abit of JB weld an as for the boost solenoid and dump Valve I cut the old nipples off the old boost pipe an welded an JB welded (for air tightness)them into the 2n1/2" pipe an I'm now running a healthy 280 bhp an 309ftlb with zero leaks [B)]
kiemcd
46
Could you post a link to the kit you used please
mike84
mike84
Dec 29, 2014
13
liverpool
It won't let me post links because I haven't done 15 posts so here is a ebay number
121790260505 copy an past that into flea bay
Something like that you want nothing less than 2.5 inch as it will choke your bhp on anything more than 240 250 bhp an nothing more as it will induce lag with are little hair dryer turbos
kiemcd
46
Thanks bud I know about the 2.5 pipework just couldn't think what kit would be best
mike84
mike84
Dec 29, 2014
13
liverpool
This is what the gurus like welly tufty ect use you will need to cut the pipes an it is trial an error just remember measure twice an cut once try an keep as many of the beads on the end of the piping as you can an get some decent julies clips miklor seems to be what people prefer where are you from
kiemcd
46
Yeah tbh I'm thinking about buying stainless piping and then I can weld it up?
I'm from Blackburn Lancs mate
mike84
mike84
Dec 29, 2014
13
liverpool
I'm going to do the same as well these ally pipes just scratch up to easy an I'm going to convert to the beach buggy turbos 410 bhp tfsi unit later in the year so want to tidy everything up at the same time have you tried lookin threw Mr silicones ebay shop he seems to be pretty cheap if you are just going to be piecing it All together
An ye not to far from me I'm in St Helens I'm always up Blackburn an Darwen in work
mike84
mike84
Dec 29, 2014
13
liverpool
Here what you will need
Bov pipe 270697267345
Atleast 4 90 degree pipe 111131521565
straight pipe 33038294236
2 of these 45 degree bend 172113835615
That's if your welding anyway you will need a few silicone bits at least just to give it a bit of give
