Yip that thread tells you everything you need to know. Definatly not a stealers job. A roll of any double sided rubber / foam sealant will do, some on here reccomend stuff on ebay that is apparently "for the job" but its more expensive than the window sealent stuff I used (a few quid in B&Q). After you do one door and know what your doing its easy, just watch you dont break the clips![]()
What did you use, the foam stuff that compresses for draughts?
Yeah kind of, its a bit more solid than that stuff though. Its the stuff the glass actually sits on in a window you stick one side to the wood and the glass sticks to the other side and it gives a seal. My old mans a carpenters so he had some that I nicked.
Yeah with you now, anything that is that type of rubber stuff and compresses when the bolts are tightened would do.
As I said in another thread, foam seal is what has already failed in the door, so replacing it with more foam seal is just storing up trouble.
People have used silicone bathroom sealant before as well, and several have reported subsequent leaks.
The biggest part of the job is the time it takes to get to the joint, clean out the failed foam and replace the seal. For the sake of a few quid (what £3 vs £12 for the whole project, all four doors) I recommend the butyl strip.
