What A pillar POD mount and gauges
rickisgrate
No idea how a turbo works
Oct 4, 2007
129
ayrshire
Does anyone know where i can get an A-pillar pod mount from for my mk3 ibiza cupra, preferably in the same colour of the original, seen a couple on ebay but they dont look that hot. Also looking for a boost gauge and air/fuel ratio gauge but want them in red to go with the rest of the interior, anybody got pics of theres?
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Nomadracing.com will supply you with a single or double pod, pretty much an exact match for the stock piller.
I personally have autometer boost and oil temp gauges in mine from ebay. they where quite reasonable IIRC. I also have a red LED in the back to match with the cupra dash lights.
Poor pictures i know ;)
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
You can screw the sender into the top of the oil filter hosing its quite fidderly to get to and usally pretty seized in, hence the reason i rounded mine :( and ended up getting a drilled and tapped sump plug from demon tweeks. Supposed to have a more accurate reading from the sump anyhow.
Im pretty sure it ended up around the £130 mark, i was about a year ago i installed them so prices may hhave gone up by now.
p34ch3y
tastefully modified
Oct 17, 2005
2,879
cambs
this was my 1st cupra i have the same pod biy instead of the ultra lite gauge by autometer i no have the phantom by autometer
__B3NNY__
OEM with a 'Twist'
May 5, 2005
3,449
Oxford
Why would it be hooked up to the fuel pump?:confused:
You can just T it off your DV, i personally have mine plumbed off from the green nipple down neat the inlet mani.
