rickisgrate
No idea how a turbo works
Oct 4, 2007
129
ayrshire
Does anyone know where i can get an A-pillar pod mount from for my mk3 ibiza cupra, preferably in the same colour of the original, seen a couple on ebay but they dont look that hot. Also looking for a boost gauge and air/fuel ratio gauge but want them in red to go with the rest of the interior, anybody got pics of theres?
Nomadracing.com will supply you with a single or double pod, pretty much an exact match for the stock piller.
I personally have autometer boost and oil temp gauges in mine from ebay. they where quite reasonable IIRC. I also have a red LED in the back to match with the cupra dash lights.
Poor pictures i know ;)
You can screw the sender into the top of the oil filter hosing its quite fidderly to get to and usally pretty seized in, hence the reason i rounded mine :( and ended up getting a drilled and tapped sump plug from demon tweeks. Supposed to have a more accurate reading from the sump anyhow.
Im pretty sure it ended up around the £130 mark, i was about a year ago i installed them so prices may hhave gone up by now.
this was my 1st cupra i have the same pod biy instead of the ultra lite gauge by autometer i no have the phantom by autometer
Why would it be hooked up to the fuel pump?:confused:
You can just T it off your DV, i personally have mine plumbed off from the green nipple down neat the inlet mani.
