Phil_beeza
461
i am thinking either white, or red
the dash is red numbers on black, my gear stick is a red stripe on a shiny top
and is there anything i need to know before splashing (ha ha....) out?
any good places to get the paint?
ebay/halfords? what sort of paint do you use?
i take it you remove the wheel, and paint the calipers in situ?
i was trying not to put it on too thick in case it sags.
Guinness when you put the seat decals on you said put it on when the paints wet/tacky did you spray laqour on straight after or wait a few hours, says i need to leave decals 24hr to dry!!!
If you use proper high temp calliper paint - I used Halfords own, it'll cover in two coats and should last a lot better.
I left my brake pads in situ but it makes it fiddly - would be best to remove the pads I think to get the best finish
i painted mine with halfords red. but that was on new calipers but its thick and dries flat, ive since rubbed them smooth again and added two more coats super shiney next is laquer when i can be bothered to do that!
