Having learnt to drive decades ago, I was taught that at 30mph 4th gear was the gear to be in. But also to "listen to the engine". I realise most cars aren't happy doing 30mph in 4th gear so 31.5 was acceptable to avoid listening to the engine labour.
Since I've had my remap and poly engine mount I can no longer get away with 31.5 in 4th gear. In fact, I can hear the engine crying for help anything less than 36/37mph in 4th. I've had a quick search and apparently a poly engine mount doesn't cause the engine to labour, but the added vibration/noise highlights the problem more.
There's a lot of remapped high powered car owners on here... my question is:
1:- Is there something wrong with my car?
2:- Should I be using 3rd gear around town (which is low enough revs and smooth enough that I sometimes forget I'm not in 4th)?
3:- Stick it in 4th and listen to the engine cry?
Everything else with the car seems fine. The power is there, picks up as I'd expect. No additional noises or vibrations other than idle (which I expected with the poly mount) and the above. But even eg 5th gear which I could previously use from 40mph plus labours until I do 45mph now. Similar situation with 6th. Any thoughts?
I only just got the Mankini reference. Although I do have a driving hat. Which apparently makes me look like a drug
