dont get an induction kit..they dont do **** all
get a resistor 'chip' off ebay..for every resistor 'chip' you add to your engine, you'll get an additional 7hp
forget the resistor comment... wind up/pi$$ take
Ones to consider:
Dynatwist made by Green (£170)
RamAir (£123)
Green panel filter (£36)
larger intake flexi pipe to go with panel filter (£20)
BMC CDA (£150+)
Quoted from martyn in another thread
1. Green panel filter in a standard airbox - ~£35
Pros
OEM Fitment/Stealthy Install
Good flow and filtration
Cheap
Low chances of heat soak
Cons
Standard airbox is restrictive
Low 'DV' noise
Looks standard (some people like 'bling')
2. Green panel filter in a modded airbox ~£50
Pros
Excellent flow and filtration
Cheap
Good 'DV' noise
Cons
3. Budget 'mesh' Ripspeed/Blitz/MMM style cone filter open in engine bay ~£30-£100
Pros
Cheap
High flowing
Great DV noise
Looks good
Cons
Sucks hot air from the engine bay
Very poor filtration
Reduced MAF life
Reduced Engine life
4. Jabbasport Cone filter open in engine bay with heat shield ~£230
Pros
Great DV noise
Less chance of heat soak due to the heat shield
Looks good
Cons
Very expensive (It's just a JR cone filter and a bent bit of metal)
Heat soak can still be an issue
5. RamAir Maxflow 'enclosed' filter ~£123
Pros
High flowing
Good filtration
Average price
Looks good
Great DV noise
Removable heat shield for more noise
Cons
Poor fitment
Not as noisy as an open filter
6. Dynatwist 'enclosed' filter ~£170
Pros
High flowing
Good filtration
Looks good
Good DV noise
Cons
Expensive
Poor fitment
__________________
Martyn
SEATCupra.net Server Admin and Web Dev....oh and resident Vag-Com geek
so the best of both worlds is the Jabba induction kit! Even with the cost, is it best to give them a call to order it im sure a company like that dont have to much time to look at emails?
Im sure ill create a cold air feed from the front to help with heat stroke and air flow!
Thanks for all the help boys and girls
Nick
if you got one i would feed it cold air, iv noticed the difference, get onto bill@badger5 and get a 80mm air feed off him
K&N
69-8251TB Product Specifications
Product Style: 69 Series Typhoon Kits
Estimated Horsepower Gain: 15 HP @ 4300 RPM
