http://www.ebay.co.uk/itm/VGate-VS4...iagnostic_Tools_Equipment&hash=item35c165f990
the above tool is very good, requires no installation, no lap top, fits in the glove box and can read and erase faults on most VW based control units and the EML on obd complient cars.
I have the same one and also have vagcom, The handheld VAG scan in the link is great to carry about with you but what I will say is that it doesn't read all the VW/AUDI protocall.
I have reset service intervals with it and airbag lights.
It reads generic codes but thats it. What I have found is when I scan with the handheld it will list some codes but then if I scan with VAGcom straight after there will be other codes which the handheld didn't read or detect.
I have mine in the car all the time for emergency use but wouldn't rely on it.
If I had to have one or the other I would choose VAGcom as its far better.
take it you dont have the multi changer then wont fit mine in my glovebox
its a good tool also clears airbags and abs etc
also just found this on ebay any thoughts
http://www.ebay.co.uk/itm/Vag-Com-V...iagnostic_Tools_Equipment&hash=item19dd29990a
They do work, and work well
yeah works a treat cheers. Installing it was easy enough..
Problem is its come up with 7...thats right 7! fault codes. Now, do these codes build up over time? for example if the hose to the dv pops off will that log a fault until it is cleared (not cleared any yet just run a full scan) or will it go on its own after a bit?
Help would be appreciated
Hi peeps:) ok so am i bein well stupid but does this scanner tell u what the fault is (as on pro jobbies what garage uses)or just give u a code no &have 2 look up what it means?:confused:
