I dont think there is alot of dfference to be honest there both aggressive valves, there was a thread about somwhere which exactly explained what was done to make it a 'race' valve.
Has noone worked on a way to possibly bypass he N75 yet...
Will it not work if you leave it connected electricly to keep the ecu happy
but bypass the hoses through a mbc or somthing..??
May look into it then. should sort out the problems and the trial and error of what N75 to get or try.
In theory you should just be able to set it just on the limit of limp mode. and all should run fine...
this is mine with hallamann boostcontroler.
as you see one line from intercooler pipe to the boostcontoler.And from the boostcontroler to the wastegate.And the n75 still site int the tip
i like that setup does it work well mate?
works very good for me faster spool and hold the boost better.and i like that i can turn the boost down.but i`m thinking to change to a 2 stage boostcontroler with switch so i can have normal boost turn the switch and then get full boost:D
like this one
http://cgi.ebay.com/ebaymotors/TurboXS-High-Performance-Dual-Stage-Boost-Controller_W0QQcmdZViewItemQQhashZitem2ea89c29a6QQitemZ200397302182QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
I've been advised my a member of staff from a tuning company (sponsers on here, mentioning no names), that a "race" valve, or anything other than standard would be a "waste of time". Reasoning behind it was that when it comes to being mapped in the future (hybrid or BT), then the "mapping company" will either map around the valve, or tell me to remove it....
So therefore, those running J valves, ECS etc (anything other than standard), is the uprated N75 actually doing anything extra than what the standard valve would since youhad it mapped? Something worth thinking about, and makes a bit of sense to me.
how do they map around it i thought becuase it caused more boost having a J Valve i thought they would map the requested boost to reach the peak that the n75 puts out. just sounds strange
why i have it in my mind is as follows
let's say the car as standard runs 5psi (easy, round numbers), and you want a map to boost 25psi
With the standard valve, would the map not just request an "extra" 20psi?
Now say you have a J Valve which gives extra 3psi.
Would the map just not request an "extra" 17psi
Same boost regardless of which valve, just the map is requesting different........
I may be TOTALLY wrong about that tho LMAO
yer i can see your point. but the J valve gives a more agressive boost and holds the boost for longer so why not have one. and map it in if that pos.
but a map could hold boost longer also.... it's the random issue of limp mode i'm not liking. If that wasn't an issue, i wouldn't think twice about getting one
The map can request boost - the valve determines what actually happens
The problem with them is that they can also spike above requested levels and lead to overboost, as commonly found with a J valve.
exactly
for that reason, may stick with standard! Think I'll trust my mate on this one (despite me initially wanting a J or ECS valve)
i put a j version on my cupra last night and dont really notice the different!
fancy sending me your standard one to try? I need someone local with a 1.8t to try theirs!
