What needs to be changed for 400 BHP and Why?
virdi
892
Middlesex
Hi all,
Taking a 1.8T to 400BHP - I understand that the rods and Valves need to be uprated.
....but what exactly is the reason?
Are Supertech exhaust valves needed because the standard one's cannot take the heat?
....and has anyone actually taken the standard rods to High 300's? Are they def' a weak point?
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
yes and yes
400bhp is higher rpm's and higher heat
std valves can and do fail, risking more ££ in damage than their cost. its building in a higher margin of safety
you can risk not doing it of course, but it is risk
virdi
892
Middlesex
Thank Bill.
What about Pistons? and compression Ratio?
Are the standard pistons strong enough for 400? and do you have to play with the compression ratio or not?
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
Thank Bill.
S3 pistons are adequate yes. Mahl pistons. std compression is also fine
