BEOWULF
I am BEOWULF !!!
Mar 18, 2006
1,186
I AM IN FRONT OF YOU
loud knocking noise coming from front
i have a terrible knocking noise coming from my left side front wheel the car as been lowered by 35mm i have had new anti roll bar links fitted about 3 weeks ago sounds like the bloody wheel is coming off it only does it when going over bumps i have jacked the car up t 2 c if if i can find nothing loose but everything seams OK u guys have any suggestions to what the hell it is :cry:
I would suggest a worn ball joint as mine only ever clunked when going over bumps aswell. Replaced the ball joint and all was fine:)
Good grammar = easier to read = more likely to get a response.
So it's in your own interest to use the Queens English!
I'm sure I'm not alone in skipping threads that take too much effort to understand. So as olaf says, it's in your own interest to make things as simple as possible for the people you are asking help from.
this is not helpful why post on the thread this has nothing to do with what my problem is AND I AM NOT ENGLISH
same goes to YOU
And a big thanks to you guys who tried to sort out my problem.
does sound like a ball joint.
But i might as well check the cv joints while i am at
Had the wishbone replaced with new ball joint and that but still is knocking.
Could it be my front strut like i say it is lowered on coil-overs and only bangs the left side
Try jacking it up! and moving the wheel left to right, and the suspensions. You may hear it! do it with both wheels
bit of a random guess here...
Could it have something to do with the subframe?
I havent had my Leon for a while now, but I had a knocking on my Mondeo and it was the subframe.
Thats just Mondeos there bad for that
