What turbo Cupra 280
Raven
223
11
How do you mean?
This is the type of Turbo our car has..
http://en.wikipedia.org/wiki/Turbocharger
If you are asking about which manufacturer / model
Here's a comparsion between the turbos used in GTI / R.
MK5 Golf GTI 2.0T EA113
Borg Warner
6/6 Blade Cast Compressor Wheel & 11 Blade Turbine Wheel
41 mm Inducer / 54 mm Exducer - Compressor
40 mm Exducer / 45 mm Inducer - Turbine
MK6 Golf GTI 2.0T EA888 Gen 1
IHI
6/6 Blade Cast Compressor Wheel & 8 Blade Turbine Wheel
40.2 mm Inducer / 52.5 mm Exducer - Compressor
41.0 mm Exducer / 45.0 mm Inducer - Turbine
MK6 Jetta GLI 2.0T EA888 Gen 3
Honeywell
6/6 Blade Cast Compressor Wheel & 9 Blade Turbine Wheel
39.0 mm Inducer / 53.7 mm Exducer - Compressor
39.1 mm Exducer / 43.8 mm Inducer - Turbine
MK7 Golf GTI 2.0T EA888 Gen 3
IHI
6/6 Blade Billet Compressor Wheel & 8 Blade Turbine Wheel
42.5 mm Inducer / 54.0 mm Exducer - Compressor
46.8 mm Exducer / 50.4 mm Inducer - Turbine
MK6 Golf R (K04-64) 2.0T EA113
Borg Warner
6/6 Blade Billet Compressor Wheel & 12 Blade Turbine Wheel
46.4 mm Inducer / 60.5 mm Exducer - Compressor
44.5 mm Exducer / 51.0 mm Inducer - Turbine
MK7 Golf R 2.0T EA888 Gen 3
IHI
45.2 mm Inducer / 58.0 mm Exducer - Compressor
47.4 mm Exducer / 54.7 mm Inducer - Turbine
Garret GTX2860, GTX2863 & GTX2867R
11 Blade Billet Compressor Wheel & 9 Blade Turbine Wheel
45.7 mm Inducer / 60.0 mm Exducer - GTX2860 Compressor
47.1 mm Inducer / 63.4 mm Exducer - GTX2863 Compressor
49.7 mm Inducer / 67.4 mm Exducer - GTX2867 Compressor
53.9 mm Inducer - Turbine
majesty78
490
Austria
Better price tag possibly?
However the turbos on new generation (Golf 7, Cupra 265/280) are reverse spin due to the construction design.
And although many people thought the new IHI turbo is an twin-scroll type due to the 2 entry ports in turbine housing, in fact this is not true. These two entry ports are only very short and do not even come close to the scroll of turbine housing.
Made some pictures back in spring 2014:
Compared to k04-064 compressor:
And turbine. Here you can also see the so called "mixed flow" turbine wheel design from IHI vs. standard radial flow design on K04:
BR
Alex
