zomby
148
Scotland
Soo, after the high winds we had last week, I went out to my cupra and found a lovely big(ish) scratch mark on my drivers window and the same sort of scratch plus a chunk out of the center plastic between the front and back driver side windows.. Turns out a slate or two had come flying off my neighbour's roof and went flying into the side of the car. Luckily or not, if I had reversed into the driveway, it would have hit the roof of the car instead.
What's the proper name for that centre plastic part (the bit that has the lil "cupra" writting at the bottom of it) as I guess I'm going to have to replace it....oh and is it easy enough to get off and refit ?
Thank you ladies and gents :)
It's the B pillar, they are named alphabetically from the front of the car should you need to know in the future :)
I think the plastic can break to get it off but that isn't an issue if you have new
Called a 'B pillar'
Front, between side windows and windscreen and A pillars
Between front windows and rear are B pillars
between rear windows and rear windscreen are called C pillars!
