what's wrong with my car???
Mar 10, 2005
1,439
Walton on Thames
I've been getting limp mode recently and have got these fault codes. Does anyone know what could be wrong??
Maximum Charge Pressure surpassed
Coolant temp sender - implausible signal
Bank1, Mixture adaption (mult.) - System too lean
Voltage supply - voltage too low
Hmmm....any ideas?
I'm thinking lambda maybe? or n75?
Mar 10, 2005
1,439
Walton on Thames
thanks guys.
but wouldn't the temp sender cause the engine to run rich, not lean??
and an air leak would make it run rich too yeah?
think i'll put my standard N75 on and see if that helps
JIMYU said:
thanks guys.
The temp sender can do strange things to the running of the car but I doubt it would effect the fueling.
The Air leak would be mean you'd be running lean as the amount of air entering the engine will be greater than measured by the MAF.
Mar 10, 2005
1,439
Walton on Thames
Yeah all the piping is fine so i'm just confused.
I changed to n75c whilst i was reseting the ecu and when i started the engine it coughed and spluttered for about 30 seconds then was fine. i drove for about 45 mins and i havn't got limp mode yet but the car seems quite a bit slower now and i've lost 4-5 psi boost. but i suppose my remap is to a j valve.
just gotta wait and see if i go limp again now!
