Wheel alignment 2.5mm out
johnx14
99
Newtownards,Co Down
just got two new firestone tyres, £113 each. The guy said the wheel alignment was out 2.5mm at the front. £23 to fix.:wtf:
should I do it for just 2.5mm?
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
If it's out then for the sake of £23 I would get it sorted or you could find you need new tyres again in a few thousand miles, £23 or £230, I know what I would do.
johnx14
99
Newtownards,Co Down
just wanna see if someone can confirm, damage will definitly occur or its too little to notice any damage. I usually dis believe the ''we check your alignment for free'' offer, as lo and behold, you have to take their word for it.
graham@pioneer
Please get adjusted as better than having to replace tyres early.
Ronin225
4,652
22
Worcester
What was 2.5mm out, camber, toe, castor??
2.5mm is outside OE tolerance so tyres will wear out lots quick and detrimental to handling
Feb 26, 2009
5,275
Wolverhampton
Think about how many times your wheel will turn in a mile. Multiply that by 2.5 mm, and that's how far your wheel will be trying to move sideways, every single mile you drive. And the only thing that will let a tyre move sideways is scrubbing of rubber on tarmac.
Although £23 seems expensive for a bog standard alignment, maybe a local garage may do it for a tenner or something?
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
I'd get mine done if they were even 1.5mm out. I am fussy but then tyres cost money and handlings comprimised with the tracking out and I drive a flippin Cordy vario tdi, it's not even a cupra lol.
turboboy111
445
Norwich
I work a garage a and you will be suprised at how much damage can be caused by "only" 2.5mm, 2.5mm is alot in tracking terms get it done or you will regret it when u still have plenty of meat left centrally but ur inner or outer edges are shot! Ask them to show u the gauges if there laser gauges the rears should be on the same number and the fronts should be the same mm but one side + And one side - that will mean it's parallel and won't cause scrubbing :)
