N Jardine
54
Northern Ireland
hey all
does anyone know if the offset on a mk2 leon is the same as the mk1? :confused:
reson being that i can get o cheap set of the old rs4's which look like multi fit and was gonna use them just for the winter
thanks
Again the search comes in handy as this has been asked before.
The PCD and Offset on a set of standard 18s are
PCD 112 x 5 ET51 7.5J x 18
You have to be careful that the wheels don't stick out too much.
Alex
PCD is the maine thing, the mk1 and mk2 wheels are different so would not fit each other without special adaptor plates. Safe offsets are ET 38- 52 any hiher and they will be stick in too much, any less and you might get the wheel arch catching under suspension compression
