I've read a bit about the delta mic spacers and seemingly the bolts that are supplied with them and very soft and can shear off if over tightened and can even come loose. Is it possible to buy stronger bolts to replace them with???
You can run 20mm on the rear on a low car (as I have done) BUT don't be fooled into thinking you can buy 20mm spacers on eBay with the bolts. Why? Cos I did too, came with bolts, but most are normal bolts. You will need radius bolts. My radius bolts cost a further £22 for 10.
DO NOT fit a spacer without radius bolts.
The car looks better, handles alot better, and I suppose it will help braking stability too (not yet tried that). Just remember to re torque the bolts after a few days as they WILL get looser.
