wheels from other car makers
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
Depends on size?
Can get 14" cool ones from older VW's
Can get 13's,
16's off renault (megane I think) etc
chipmunk82
MK3 Ibiza Cupra
Aug 26, 2010
119
Stroud
When i had my polo there werent any spigot rings and the car rattled at 50, bought some off ebay for £5 from rimsntyres so easily sorted
Seatmann
Rough around the edges
Sep 16, 2010
5,541
10
Scotlanda
7.5 & 8j? That's 7.5 inches and 8 inches, hopefully you got two of each so you can use them as axle sets. You'll more than likely need 5mm spacers to fit them, at least for the front. That's what I've had to do with mine with the same E43 offset, I think they're about E37 for standard but not 100%. Just make sure they clear the brake calipers by a few mm before you drive anywhere.
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
yeh :) 2x7.5's (fronts) 2x8's (rears) and i currently have polo steels in 14inch which are et43 i believe and there fine, mines only a 1.4 so brake clearance isnt realy an issue :)
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
seatman, I don't think you need spacers, as the original ronal mulitspokes are 6J ET38
and them steels were probably like 5-5.5J ET43
but never know until trial fitted :)
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
yup ill try them tomorrow when im done scavenging from the local scrap yard :)
in-fact does anyone know the measurement from the front of the hub to the front/outer of the suspension ?
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Yeh I had to use spacers on my 1.4 polo I used to have just to clear the calipers really. That's the main thing and also don't want them to sit to far in and look naff.:D
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Yeh I need some big ones for the rear of my Cordy vario, the wheels sit way to in. What size diameter are the Vauxhall wheels?
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Cool that should look quite good, my wheels are 15's but I'd prefer them to be wider, they're about 6.5 I think.
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
Ive got a set of Camille gottis (look like borbet A) that require tidying up with out tires for sale there 15x7 et 28 i believe if your intrested ;)
suj
Wheel Connoisseur
Jan 1, 2009
5,808
Birmingham
seatman, seeing as he has staggered widths, 0.5" wider rears, equates to a 12.5mm adapter (compared to the fronts)
as the widened band will be be on the outer lip
so only spacers he'd need is to clear the brakes like you said (well, if he needs it lol)
Seatmann
Sep 16, 2010
5,541
10
Scotlanda
Cheers but I'm skint for now, been spendin dosh on springs, brakes, oil, fuel, tyres etc.
I think the tyres might be an awkward size, not common usually means more dosh.
STom
This is my Hungarian friend.
On the car was fit in
Mercedes wheel 8x16 (ET36 & ET34). I think it looks really good.
img.carstyling.hu/usercars/00/05/57/89/55789_1288857441.jpg
img.carstyling.hu/usercars/00/05/57/89/55789_1287670822.jpg
This wheels is another, which looks good on Ibiza.:)
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
they actualy look quiet cool :)
any way heres some of my trial fit
