masterfrodo
266
8
Just looked on the TPS site for the leads using the code 038971220D, but it didn't come up with anything
Its for my 1.9tdi Cupra. Four wire harness
TPS definetly sell them as I've had one in the past.
Sent from my SM-G930F using Tapatalk
I found that one as well. But its not identical. Its a C not a D so not sure if it will fit or work?
i had my soldering iron out yesterday.
Pulled the connector rail off the glow plugs (mines broken on cylinder 3), cleaned up the connectors and applied a blob of solder on 1 and 3 and the light has stayed out. I scanned it for codes earlier after a couple of hundred miles and so far so good.
Would be well worth checking yours.
