jason-jm
414
I have a new sensor in hand. going to jack the car up and put it on axle stands after work and fit the new one
anyone point me in the right direction as to where it is exactly
there is more than one is there not? i know it screws into the exhaust from the outside, My exhaust is aftermarket, does it normally plug into the cat, or in my case decat?
you can change it parked on a high kerb, plug in the plastic bit first in the engine bay and feed the pipe down then get under the car and screw it in to the exhaust.
where in the engine bay?
its down behind the back of the engine, on the left of the turbo (from the front)best plan if you dont know is to follow the cable up from the exhaust from underneath, there will be 2 plugs, i think 1 brown 1 black - i *think* its the brown one.
