Your maf's dead... I'll put money on it.
You're hitting peak torque ~ 240lbft, then flatlines.
So either a dead maf, or an airbox full of dirt
airbox is needing to be sorted as it has a temp inlet to it which is not completely air tight, and maf i did think about so ill look at that, cheers mork so if i get them things sorted and then another remap it'll be ok??
If you get those things sorted you might not need another remap! If you MAF has died / is dying then the boost will drop by a fair amount, which will give you much less power.
When my MAF died I only got 6PSI and 160bhp from a LCR!
o blimey i see i thought that they may of flashed the ecu as im sure i would of been expecting about 200+ but if maf could affect it that much would the map still be on there??
Only one way to find out! You might find it's not the MAF, you might find it is and the remap is still there, but unfortunately the only way to test for sure is to change the MAF. As said though, a dead MAF can make the boost drop quite a bit, which you in turn mean you have a massive power loss. Also the MAF dying could cause slightly erratic readings, which might explain the big spike in your graph!
looks spiked as well not good, stretch heres my curve if you which to use it
oh and tech bods is this ok?
Given that on the same day I achieved:
210.8bhp @ 6105 From a peak torque of 222.4 ft lb
I would say that its not holding boost at higher revs. I'm no expert though.
well heres the map guys so you techie heads what you reckon something simple or not will getting another re-map sort this out???
M0rk can advise much better than I can, but surely the fact that you are hitting such high torgue peaks does it not mean that your remap is there?
Could it not be something simple like your dump valve letting go?
The remap is there, as you say it's making the boost.
as it flattens out to a plateau it's either the MAF, or a physical obstruction (or the remap is utter ****)
utter **** i like that one lol
Well ill get maf done anyway as it was a second hand one that seat put on, also my engine management light has come on but engine runs smooth as so will see if thats something to do with it!!
cheers
Right have got new maf on way so thanx for that guys, hope this is the prob the one i had on there was 06a 133 356H so god knows what thats from :confused: :confused:
so hopefully get this in and see how it feels, thanx for all the help guys!!
just as well u put your car on the dyno rob as it has confirmed you have a problem! good luck with the new maf too
if you need vag com u know where i am! ;)
yeah cheers james knew it wasnt right and when i saw the read out i was like WTF, also maf says different code so i hope thats whats up, so bring on tues with new maf!!
BBBBBBBOOOOOOOOOOOSSSSSSSSSSSSTTTTTTTTTTTTTT!!!!
well if the maf has the wrong code then surely theres your answer! fingers crossed! :)
ah yeah almost forgot that cheers, thats turn off car isn't it disconnect batt for half an hour and tb alignment is open bonnet and drivers door with ignition on?
