Guest, 🚨New Stock alert: Premium CUPRA valve caps now available in the store 👉 Order now from the merchandise store
Do the bushes just make it a bit smoother? I.e by fitting just the short shifter alone, will the gear changes stay as smooth/rough as the standard shifter but it will just be shorter?
Thanks for everyone's help. The only thing that concerns me is warranty. It's going in on Friday for a service but I've also asked them to check the clutch pipe. Back in May when I got the car this pipe had come loose and was causing a vibration. I have the same vibration again so I assume it's the same issue. I'd hate to get it fitted tomorrow and then find that they won't fix it because they say the short shifter is linked, and it's not like they'd not know it was there either![]()
It's such a quick and easy job u could swop them over again when it goes into the garage if u were really worried
Hi all, new to the forum and recently purchased Leon 51 plate 1.6 s would anyone be able to tell if I can get a 5 speed short shifter for it, the help would be appreciated.
Hi guys,
Im about to invest in a shortshifter but before i do, i wanted to know a little more info.
Is it really worth spending double the money for Forge? Or is the ebay one just as good?
Ebay: http://www.ebay.co.uk/itm/Seat-Leon...CarParts_SM&hash=item4ab629eac1#ht_500wt_1089
Forge: http://www.autops.co.uk/product.asp?catalog=030403&productid=310189&order=&manu=
Let me know
