whooshing noise in or near throttlebody
killer205
206
i took my throttlebody of last week to clean it i put it back on today and started the car all was fine it idiled a bit high but then i went for a drive and now it makes a whoshing sound when i let the acclarator go soon as i press it again it stops any one have any idear what it could possibey be i also have the inlet manifold of and the idile vales of but there all back on tight HELP
its the ABF engine 2.0 16v
thanks for any replys
toonfiend
Hail to the Plug!!!!
Jun 27, 2008
159
Alright mate, It sounds very much like a vacuum leak somewhere. Check all your associated hoses again make sure all the clips are tight and there all connected properly. If in doubt put new jubilee clips on. Also, did you use new gaskets? When I did mine i used some loctite instant gasket on the throttle body and got a new inlet manifold gasket from the stealers (about £3 i think) Make sure the mating surfaces are clean and smooth, (give them a scrape with a razor blade). When your engines running get someone to sit and rev it and you can listen under the bonnet, you should get a good idea where the airs getting in/out.Hope you get sorted....
killer205
206
i aint got a gasget on the throttlebody as when i took it of it dint have 1 on it but i have taken all the sensors of the throttlebody and put them back on and it seems to idile high now then sometimes it drops a bit then gose back up ill put some loctite on it 2day
toonfiend
Jun 27, 2008
159
That could be the problem, 2 bits of metal put together no matter how smooth arent going to be 100% air tight, I reckon a bit of instant gasket will sort it, not had any trouble with mine since.
toonfiend
Jun 27, 2008
159
Possibly, if theres air getting in, your ECU will fire more fuel in to compensate and will lead to higher idling. Could also be your ICV, have you cleaned it out recently? They get gunged up with all manner of filth, take it off and rinse it through with some parraffin and give it a scrape with an old toothbrush, I had a problem with high idling, cleaned out the ICV and been OK since. Id do the throttle body first tho...
killer205
206
yea i did the i cleand it with some petrol and got ride of the crap i also put it own breather filter on it but il try the throttlebody first
cheers m8
toonfiend
Jun 27, 2008
159
Yep, if your ICV is clean id defo go for the TB, let uz know how you get on, Cheers.
killer205
206
hi m8 your advise was 110% correct it sorted the problem out i put some sealant on and made sure it was really tight and it stoped the noise and stoped the high idling
thanks a lot m8 :D :D:D:funk:
jamesypyk
Gettin faster
Jan 14, 2009
96
pollok glasgow
hi m8 i got the same prob on my lcr just fitted a KnN 57i after painting my inlet m put it backto gether it idles high on start up and wen i put foot down it wooshes a bit much i think wen i press the acclartor then stops then starts its doing my head in cause its really loud
