Why you should use vag-com to re-set the Throttle body
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
This is what happens when aligned with a vag tool like vag-com
http://www.youtube.com/watch?v=DsI8tKgfmFs
This is what happens when you leave the key in the ignition
http://www.youtube.com/watch?v=xB5DIuuEC_8
The top video actually does an alignment, and the figures change for the vag-com screen like below:
http://www.youtube.com/watch?v=HMU_riJ00zo
as can be seen, the start figures are different to the end figures, because the throttle body is actually being measure while being aligned.
Taken from http://uk-mkivs.net/forums/AddPost.aspx?ReplyToPostID=1900058&Quote=True
Select Control Module
Select "01" Engine
Select "04" Basic Settings
In the first group box type "060" and hit GO!
You should see the display below and watch the "Step count" step through until it reaches 8.
Reactions: Grayboy and adon30
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
I always get noticeable results from a vag com reset, mainly MPG.
Well worth doing now and then.
Jimski
Jimski
Back to the fold!
Nov 3, 2007
1,350
Staffs
IIRC its not a reset, more of an adjustment, to obviously "re-look" at your driving style, fuel type, temperature etc.
Jimski
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
I'm glad this has been posted as I asked last couple of weeks and some people seem to think you can do it without....very helpfull post.
Perhaps this could be a sticky?
dizzydiesel
At the risk of sounding like a total idiot.....can you realign throttle body on a TDI using vag-com?
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
You have succeeded . . .
Diesels
Have
NO
THROTTLE
In case you're still wondering, that means no.
dizzydiesel
Ok, the Ross-tech makes sence then.
I wasnt sure if TDI had a throttle body......probably getting confused with the EGR and manifold.
I hold my hand up - idiot. :doh:
adam cupra 20vt
Built Not Bought.
Mar 31, 2005
6,162
Mud Hut
From reading the bottom link in the first post it seems sometimes the ECU does it itself?
http://www.waheedkhan.com/vagcom/vagcomthrottlebodyadapt.htm
"Throttle body adaptation is a reset of the throttle body flap to align it to the accelerator pedal as the TT is Drive-by-wire.
Its recommended to be done at a service and then always if the battery were to be disconnected, there are 2 ways to do it.
1. Switch on the ignition and leave it on for 30 seconds.
(You should hear some clicking in the engine bay, always after a battery disconnect)
This is not guaranteed to happen as the ecu decides if it needs doing,
if you disconnect/reconnect the battery first then this method will definitely work.
or
2.Use VAG-COM procedure as described below"
I wonder how the ECU decides if its going to do it or not? also it says "if you disconnect/reconnect the battery first then this method will definitely work."
Any thoughts on this or am I missunderstanding?
