Will small boost leak show up on a code reader suitable for VAG cars??
Rgm racer
317
As title,will a VAG compatible fault code reader show up anything for a small turbo boost leak?
gti_jones
VAG Technician
Jan 5, 2012
73
Sussex
on what car? if it was going to show up anything i would of expected to see an engine light. if not anything that can read measured values to show expected boost and actual boost should do.
do you suspect you have a boost leak then i take it?
Rgm racer
317
Its a mk1 LCR 2005.Suspect i may have a small leak.Will be checking all pipes best i can over weekend and if i still suspect,appreciate garages can do pressure tests but just wondered if any fault would likely show up on a normal code reader?
