Isn't it a case of fitting spacers like Reuvers said, 4 to 5 stud adapters? But they are 20mm thick so wouldn't the alloy need to be and offset of ET15 and when added to the 20mm spacer would make it ET35 therefore suitable for the Ibiza?
if you use 20mm spacers to get the 4 stud to become 5 stud then the ET has to be 15 or else the wheel will stick out too far...that will also be a reason not to pass MOT, not even speaking about your arches and wheels that rub and ruin each other...
