Tell
It's out and you can install it. Did it on two laptops. It's in the pre release test mode as those late month updates. If you follow the instructions and the servers are good. Slight 5 minute delay till you get enrolled.
You need to do the final step in the video else you'll get other builds for next year. Only select the bottom box of what you want from the development releases.
Got fed up with waiting for 25h2 and since it was on the final test build prior to release like the monthly test builds thought, blow it, will install it. Nothing shattering about 25h2. There isn't suppose to be.
Second lap top was moaning about the environment string. Googled it. Wouldn't allow me to accept the terms. Opened up the area and suddenly allowed me to accept the terms. First laptop was fine except it needs about 5 minutes to enrol you on the program and reboot then you see 25h2 being offered on a check for updates. Could be Microsoft servers get busy.
All good the launch release will magically appear as an update using the guys above instructions. Pre release till then.
As for putting it on unsupported machines using the iso, wait. The final iso isnt out and last year people on unsupported hardware got stuck on the wrong release. I found an iso but concluded I might end up like people last year with a development release unable to get off the release since it was unsupported hardware, catch 22. You got to wait for the official release of 25h2 to put it on unsupported hardware where the server method the same as last year will work. I'm waiting on that, then will edit the other thread for unsupported hardware.
Reactions: Syphon
Posted the unsupported PC way of doing it here. See end post. You use the "server method" for that.
After Monday 29th September test release of 25h2 updates the unsupported and supported build release have come together in the build release code. The iso was the production release to hardware companies that I used in that link. Was getting slightly concerned I'd got two build releases of 25h2 but now back on track, its the same release going forward. Thought by some, the second Tuesday in October circa 8pm GMT may be the actual release on Windows 25h2 but us early birds have it already 👍.
Edit 30th. Its out.
If you have a fully supported Windows 11 PC you can sit back and wait to get the invite (toggle get updates as soon as available) or take the more direct action to nudge it along. In that case you need the files in the link above and take the first option (Installation Assistant). What to do is explained in this video:
After the feature update which is what this is, you are suppose to make another Recovery Drive USB. Don't forget and back up. Normal operating procedure.
If on unsupported hardware see the other thread and look at 25h2 post of that.
Lucky people if you followed post 1 this weekend Microsoft knocked a lot of people off the Insider programme which then caused the update system to try to update to 25h2 when it was on 25h2, fails and the update sticks. The solution found by others is to put it back onto the Insider programme. The bottom option then the issues goes away. Rejoin the programme 💡.
Reading around it looked a bit tricky to take it off the Insider programme properly we no issues, although one was led to believe that was what was going to happen automatically from the video. No, not at the minute. So an easy solution to get rid of that pending update that isnt required that sticks it, is to put it back on the programme. Its clever enough to know it cant do it after 90 minutes... but will re-try and re-try till its put back on the programme. Make Microsoft Great Again is a bit tricky 😉.
I'm sure there will be something published that clearly says how to get off the Insider program cleanly without a clean install. There are home brew programs that tinker with the release details to switch channel but left that for another day until more is known about the current issue of what happened.
Well this is last years 25h2 roll out to get it early. Might be public enemy number 1, well the author. Microsoft messed up those on the developers channel a few months back. One of our laptop in the last period got off the developers channel by itself and the release tallies with the 25h2 core releases. Mine on the other hand is on 220. 300 will eventually be the 26h2 release so I'm on course to beta check 25h2/26h2 so the blurb says. They also re released the activation code for another year or so on the insider program.
All fun so I'm sitting on the 220 release and we'll see what happens as we edge closer to 26h2 coming out. Circa end of September / October is said.
As for the unsupported hardware the server method is still suppose to be available. That switch is kept in by Microsoft so that server based hardware can run Windows 11 on unsupported. Last year for 25h2 there was a method to glue together the updates to 25h2 from 24h2. Published after I used the ISO server method. Will look out for that, if published too late I'll just use the production ISO for 26h2. The glueing together method should be faster. "Enablement packages". Last year's instructions which obviously for 26h2 will access different files:
Will be looking for a post similar.
So we wait in anticipation :LOL:.
The fun begins with 26h2. Yesterday it was released to the Insider programme
My name may or may not be mud on getting lasts years early release of 25h2 when Microsoft scattered beta installation testers in the year. Some got off it so became normal 25h2 users others they thought were so good they kept them. The Pureinfotech instructions were suppose to leave you with 25h2 general release. No you became an ongoing tester.
Bit the same this year with 26h2. It took 2.5 hours to download and install works fine. Post the instruction / video for anyone who fancies not waiting although it can be risky. 200 series release that I was on for 25h2 testing for 25h2/26h2 features proved difficult to get off at one stage so decided I'd try for the 26h2 pre release... why not 😂. End the uncertainty and get a new set.
For the unsupported hardware you got to wait for the final ISO release circa start of October. These are got out for those Xmas laptops being sold etc.
Instructions...
It is this announcement from Microsoft:
I used this video, stopping and starting it to get the instructions:
We will see 😂... all seemed to be fine and I went to bed. Take care if following the video not to hit 26h1... that is something else... only 26h2.
Having installed it on a second machine that was a lot faster ~ 60 minutes. Mine was on 220, was theirs was on 200. Suspect if you have got a beta testing version of 25h2 / 26h2 its slower as it untangles the 220 release gets you back to vanilla 25h2, then moves forward.
The installation on the second machine had different insider screens since that one wasn't plotting anything. But like Microsoft products things can get idiosyncratic.
The "water mark" on beta copies has now gone so this is now a lot like last year so this is a pre release checking installation processes rather than anything else.
Edit. The 2.5 hour delay was due to 25h2 being updated so the "enablement package" could be run so then effectively followed this thread. The enablement packages works behind the scenes on supported hardware or you can it on unsupported hardware:
