h17och
the hunt is over. 460bhp
Sep 1, 2005
3,504
Dunstabubble
i had a leak and my car filled up with rain water!!
ive since dried it out but now the windows dont work!?
ive tryed them with the key, when you hold it for a few seconds when its in the door and that doesnt work either!
checked fuses! cant see a problem
done a search...cant find nothing!
the window switches light up but dont do anything!?
can anyone help?
HoocH
Both windows? Can you operate the passenger window from the passenger door or are you trying both from the drivers door? Could be the switch.......
tryed all the switches!! nothing works!
checked the connections,no corrosion!
i test the connector at the motor and i couldnt seem to get any power so i think the motors are ok!but for some reason the im loosing power between the switch and the motor!
im only getting 8v at the switch! is that normal?
where is the fuse for the windows? dont think its one of the ones below the dash!?
cheers
HoocH
sorted, dont ask, but...the fuse had fallen out and i found it tucked into the loom but it was higher than the slot it goes into...explain that!!??
HoocH
where abouts are the window fuses. i had a look and there is only one fuse above the relays.
thats the one! the other 5 are for electric roof etc (optional extras, or just other features ibiza dont have) thats why i got confussed!?
Where are they by the way?
My passenger window has stopped working and i wanna check everything first before i check the motor.
there is one fuse for the both phil! just above the other fuses, and above the relays!
leak sorted mike, windows alworking!
HoocH
