AdamRoutley Use The Force!! Feb 22, 2007 1,827 1 Walsall www.myspace.com Jan 18, 2013 #1 Is this something you can change yourself? As I think mine is fudged! No sounds coming from it so I know it isn't an "empty" problem.
JP6 Active Member Aug 18, 2012 189 14 West Sussex Jan 18, 2013 #2 There you go! Last edited: Jan 18, 2013
marty_34 Active Member Apr 21, 2012 1,175 2 TEESSIDE Jan 18, 2013 #3 are you sure you havent just blown the fuse if its been too cold when trying to use your wipers? i did this couple years ago
LukeFR Jun 6, 2011 806 1 Bradford www.snowdropitsolutions.co.uk Jan 18, 2013 #4 Fuse is most likely cause in this weather as they frozen it blows it.
AdamRoutley Use The Force!! Feb 22, 2007 1,827 1 Walsall www.myspace.com Jan 18, 2013 #5 I thought it may be. What location is the fuse? dash or engine? What number is it?
LukeFR Jun 6, 2011 806 1 Bradford www.snowdropitsolutions.co.uk Jan 18, 2013 #6 Wouldn't know I'm afraid without checking my handbook.
AdamRoutley Use The Force!! Feb 22, 2007 1,827 1 Walsall www.myspace.com Jan 18, 2013 #7 Thanks for the pics jp6..what website is that from?
JP6 Active Member Aug 18, 2012 189 14 West Sussex Jan 19, 2013 #8 It's not, it's from Elsawin, the official VAG workshop manuals.
Nath. The Gentlemans Express Jan 1, 2006 8,615 16 EASTLEIGH, HAMPSHIRE Jan 19, 2013 #9 AdamRoutley said: I thought it may be. What location is the fuse? dash or engine? What number is it? Click to expand... 20amp fuse (yellow) behind the dash panel that is visible when you open the drivers door. Don't quote me but fuse no 36 rings a bell.
