Wiring Audio Sub
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
Hello to all, i have a want to put my sub back into seat leon 1.8 Turbo 2000. but i have a problem with wiring, i cant find a port to feed the battery live from engine bay into the car.
On the passenger in the engine bay there use be suckion pad but that appears to be blanked out and i dont want drill in as there could be used for something.:cry:
Any suggestions :confused: i want to do a good job and not cowboy
warren_cox
Back from the dead
Not the best of pics, but I routed mine through the plastic ducting that went through the bulkhead on the right hand side behind the airbox. Had to take the glove box off to capture the wire coming through, then take it down under the carpet on the passenger side of the vehicle.
warren_cox
Back from the dead
does the cd changer has to come out for me able to able to grab the wiring?
I took the whole dash piece out, never thought to disconnect the multichanger. Didn't have any issues, other than you need to be very careful not to upset the passenger airbag switch as if you do you'll get a warning light on the dash which will need to be switched off by the dealers.
skidder
BERK! FEED ME
Aug 9, 2006
93
Aberdeen
I used pabs website leoncupra.co.uk. Ha has a great guide in there, took me 10 mins to run the feed back to the boot for the amp. Much easier than rooting around to find somewhere. Keep a trusty coathanger to hand!:D
