Would it be wise to get a cambelt change
Mk2Ibiza
232
Middlesex
Hey guys, sorry for butting in. Anyone done a change on the 1.4 8v apg engine?? Hard stuff? something i can do myself??
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
Ive done mine and it were very simple, if your half decent with a set of spanners you'll be fine, but if your not id recommend you get a haynes manual to help you along :)
Mk2Ibiza
232
Middlesex
Easier than a pedal box replacement?? Would i need these cambelt kits i see for sale?
Because if thats the case im better off getting myself a trade discount at where i work.
Seat-Chris
MK2 1.4 Sex :D
Jul 20, 2008
253
Derby
Haven't done a pedal box but id imagine it'd be easier :) and yeah you'll need a cam-belt kit comes with tensioner, belt and 1 idle pulley.
Gav_F
187
well im assuming the APG engine is similar to the AEX engine! worst thing i found was getting the crank pulley bolts out, someone had managed to round off 3 of the 4 6mm allen bolts so i had to hammer a socket onto them but that was it :) haynes manual explains it, abit to detailed though (i only wanted the timing marks) :D
Mk2Ibiza
232
Middlesex
Looks like i need to pick up a haynes manual at work, and see if im comfortable doing it.
Dont wana mess up timing and killing my engine.
Although would be a perfect reason to look for a more powerful car.
chipmunk82
MK3 Ibiza Cupra
Aug 26, 2010
119
Stroud
My car had a cambelt change at 49k in 2003, its now on 86k - so although under mileage age should be enough to get it done again for peace of mind right?
Do I need to get the waterpump done at the same time? It's a MK2 16v cupra
M1KEH
M1KE
Oct 27, 2007
2,336
The Middle
I would get the belt done, they deteriorate with age. Water pumps not too much of a problem on these as is not driven by the cambelt so I wouldn't unless you have the cash to throw away.
