Changed a couple of the settings in VCDS today, took the car for a spin and the difference is superb.
Changes made.....
In VCDS Select Control Module, go to 03 ABS Brakes, then 10 Adaptation, go to Channel:
Channel 09 Brake Assist
There are 3 settings for this
0-center (stock setting)
1-small
2-hard
I changed this from the stock 0 setting to 2 and this has made the brake pedal more responsive to smaller inputs. Feels more positive in use, especially under enthusiastic motoring.
Channel 36 XDS
1-weak
2-strong
Again I changed this from 0 to 2 and this one mod alone makes the Polo into a different/better beast under hard driving. It acts almost like my ED30 did with the Quaife and yet doesn't feel as fidgety. Seems more planted around bends and that much better to push through the corner on exit. This mod comes with a five thumbs up...
Also got a chance to look at the log blocks that can be done and FOOK ME there are over 400 of them for the 1.4TSi
Annoyingly the measuring blocks all have different units of measurement and so for me to fully understand them I've had to wikipedia all the conversions to allow me to see what is what.
As I haven't got the water/meth running at the moment (no meth left!!) I thought I'd get stage 2 logs up and after faffing with conversions got the following.....
Block 201 - engine torque - max 350.1nm = 259lbft @ 3497rpm
Block 196 - Mass flow through throttle valve - 691.7kg/s = 192.2g/s = through the 0.81 division approx 237.2bhp
Typical schoolboy error was not pressing the turbo button and only getting a sample every 2 seconds so may have missed peak mass flow and engine torque alltogether!!
Changes made.....
1-small
2-hard
Channel 36 XDS
1-weak
2-strong
