I had a forge splitr on mine and it was loud! you dont have to have a dump valve that only vents to atmosphere for it to be loud!!
Having one that dumps only to atmosphere will give you a fault code anyhow
you know you have a mk3 ibiza when you have just spent 6 hours fitting HID's properly and now they fog up all the time!
you must have drilled a too bigger hole for the dirt covers![]()
Yep, would u go in from the back ( where you fit the bulbs )
Or would you just take the front casing off ?
Ive tried leaving the lights on with the front covered up but no success![]()
take the blast plastic covers off the back. put a few sachets of the silica gel beads in there (leave them in the packaging) then put the covers back on. this should work for a good time. if you ever find them 'misting' up again take the gell packs out, shove them in the oven for a good few hours and then put back in the light housing.
putting them in the oben bakes the gell and makes it release all the moisture they retain.
