What chambers under the rocker cover of a Cupra R are water cooled?
B3LSY
Right can anyone tell me what chambers under the rocker cover are water cooled?
As i have a problem i took the bracket off which covers the coilpacks which is on the right side,took out one off the bolts and there was a slight bit of water/coolant not (sure) not alot but i took the bolt out then screwed it half way back in and the water was still there, there is now vacum or air coming out the hole/thread any ideas anyone? the engine is still under warrantty so its going in saturday any ideas anyone?
B3LSY
think it was a false alarm just went out and took the bolt out stuck a few cotton buds down the thread and its bone dry,havent got any pics mate its the bracket that covers the 2 right side coilpacks,ive been loosing cooliant the past few weeks,and some white smoke in the mornings when it starts up
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
sounds like that wants looking into more white smoke not good thing.
cold mornings make show more signs of smoke but should clear.
may have you washed your engine off or something if there was water there before.
B3LSY
the smoke does clear only lasts a few minutes its the coolant going low after week thats worrying me mate,we had stupid amounts of rain yesterday and i was driving in it
CupraMVR
Oct 19, 2006
1,371
Crewe Cheshire
no wet carpets in the car/
i just done a heater matrix in a lcr they was split. using water about the same 1 week a header tank
coolant temp sensor is common place for them to leak aswell
B3LSY
i have had the rear passenger footwell full of water before threw the door seal,just hope its not head gasket engine was only rebuilt 10 months ago still under warranty so
Lodgey180
WoOoOoOsShH
May 3, 2008
1,046
Middlesbrough
www.mootr.co.uk
there is no coolant lines that go that high over the rocker cover anyway ?? strange how there is water n there especailly with the heat of you driving it and you still have to seat sport cover on ??
B3LSY
some good news its not the head gasket gone on the car, coolant is leaking from the header tank cap,and the car has multipule miss fire coil packs
