Tam_171190
Hi all,
Recently bought a 05 fr tdi ibiza with 120k. Recently iv noticed the coolant was at the minimum mark so I went to top it up. Even when stone cold, if I open the expansion bottle there is quite a bit of pressure and coolant will gargle out,however once I open it the coolant level is at the max mark. Initially I though it was the headgasket but I have not lost any coolant or have any overheating issues. The car will heat up normally and sit around a needles thickness below 90 degrees and won't budge from there! Also the coolant is clean, as is the oil. Any suggestions would be appreciated.
Tam
Tam
